It is currently Mon Jul 21, 2025 5:10 am
PostPosted: Thu Feb 01, 2007 9:09 am
Here's another take on these for binding routing. Got it off kitguitarbuilders site.
Chris Nielsen
Soquel, CA.
PostPosted: Thu Feb 01, 2007 9:42 am
Nice! The contact area between the bottom of the base and the guitar's top or bottom seems fairly large. I can see that some wood is removed from part of the base, but is the remaining contact area small enough not to affect the angle of the cutter, thereby the rabbet angle?
PostPosted: Thu Feb 01, 2007 9:50 am
This looks very similar to the one Jim Williams shows in his book .
I built one with the same principal ,except mine has two bearings to run along the sides , and a much smaller footprint (donut ) .I've also included a micro adjustment for hieght and depth. My donut is also adjustable via shims ,to suit either the back or top radius'
Craig Lawrence
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Thu Feb 01, 2007 10:00 am
Looks like it's from th UK, Trend T3 trimmer and one of Axminster's bits of kit behind it. I just love Axminster 'white' goods.
PostPosted: Thu Feb 01, 2007 10:21 am
I didn't make this myself. I pinched the pics from some builders blog that I found at kitguitarbuilders.com. He's using a big full sized router, hence the rather large base. I may try making something like this scaled down to my Ridgid trim router. I really like the way the handle is integrated into the design. Looks like would make for a firm, sturdy, steady contact to the sides.
Chris Nielsen
Soquel, CA.
PostPosted: Thu Feb 01, 2007 2:12 pm
Chris, it looks like it would work well although i'd find a way to incorporate bearings that would index the sides. Other than that, i find it 's a pretty cool jig that would be sturdy by a firm handgrip.
PostPosted: Fri Feb 02, 2007 7:34 am
Serge,
The guy who made this said he uses some sort of 'slippery tape' on that indexing edge. Maybe teflon tape?
Somewhere else I saw where someone used 1/2 of a door hinge with bearings mounted on a pin. I might try that if I can find the right size bearings to fit a hinge pin.
Chris Nielsen
Soquel, CA.
PostPosted: Fri Feb 02, 2007 11:25 am
Chris, its probably something like slick strips.
PostPosted: Fri Feb 02, 2007 11:30 am
Lillian,
Thanks!! That looks like just the ticket, and will save alot of work over trying to fit up bearings. Slick strips look good for lots of uses. I'm ordering some now.
Chris Nielsen
Soquel, CA.
PostPosted: Fri Feb 02, 2007 2:58 pm
First name: Roger
Last Name: Labbe
The distance from the cutter to his thumb is pretty scary to me. No thanks.
PostPosted: Fri Feb 02, 2007 3:18 pm
[QUOTE=Arnt] Nice! The contact area between the bottom of the base and the guitar's top or bottom seems fairly large. I can see that some wood is removed from part of the base, but is the remaining contact area small enough not to affect the angle of the cutter, thereby the rabbet angle? [/QUOTE]
nice work.....yes i agree with the above ...i have made and used a jig like this before and ended up cutting out most of the contact area except for 5-10mm at the top and bottom because it wasn't so smooth to use and if the sides arn't real straight all that contact area isn't very forgiving . but it did the job...Ended up building one with bearings though because it just feels a lot smoother to use.
PostPosted: Fri Feb 02, 2007 3:19 pm
[QUOTE=gratay] [QUOTE=Arnt] Nice! The contact area between the bottom of the base and the guitar's top or bottom seems fairly large. I can see that some wood is removed from part of the base, but is the remaining contact area small enough not to affect the angle of the cutter, thereby the rabbet angle? [/QUOTE]
nice work......yes i agree with the above ...i have made and used a jig like this before and ended up cutting out most of the contact area except for 5-10mm at the top and bottom because it wasn't so smooth to use and if the sides arn't real straight all that contact area isn't very forgiving . but it did the job...Ended up building one with bearings though because it just feels a lot smoother to use. [/QUOTE]
PostPosted: Fri Feb 02, 2007 3:24 pm
Chris, i just thought of something, how about adding a narrow piece of UHMW plastic, that would be slippery too.
One question, is this jig adjustable for binding width, by retracting the handle from the wooden base under the router?
PostPosted: Fri Feb 02, 2007 3:31 pm
I agree with Rodger. If this is a jig you would like to build, please consider putting something between your thumb/fingers. Sorry, its a mommy thing. Ryan is still nursing his fingers back to normal after being incredibly stupid (and just as lucky) around the table saw. They can't sew up hamburger.
